Go Back   RC-Monster Forums > Support Forums > General Nitro
pulling a flywheel?
tallyram
tallyram's Avatar
pulling a flywheel? - 09.21.2006, 09:46 PM
how do i pull it off?
  Send a message via AIM to tallyram
squeeforever
squeeforever's Avatar
09.21.2006, 09:58 PM
Sometimesa flywheel puller is necessary, but given you have the clutchbell off, the shoes off, and the clutch nut off, just pry on the sides witha screwdriver gently until it pops off. Be sure to alternate sides though...
tallyram
tallyram's Avatar
09.21.2006, 10:07 PM
thanks squee! will this damage the flywheel?
squeeforever
09.21.2006, 10:12 PM
It shouldn't....
rchippie
rchippie's Avatar
10.10.2006, 05:37 PM
What i do sinice i dont have a gear puller here is what i do . First you take off the clutch bell & clutch shoes & clutch nut. Then you turn the motor over & put the crank shaft on something solid. Then i take a adjustable wrench & adjust it to fit the back side of the flywheel & tap both sides with a hammer & the flywheel pops right off. I hope this helps :027: .
REAL MEN RUN BRUSHLESS
tallyram
tallyram's Avatar
10.10.2006, 10:46 PM
thanks hippie, but i already bought a flywheel puller. it works really well!
rchippie
rchippie's Avatar
10.12.2006, 11:25 PM
You did the right thing. You should always use the right tool for the job, so you dont screw anything up .
crazyjr
crazyjr's Avatar
10.13.2006, 08:06 PM
I just tap with a screwdriver on all sides to prevent possible bending, should fall off with a few good taps
tallyram
tallyram's Avatar
10.14.2006, 12:25 PM
thats what i thought. ofna really had this one on there. my puller made quick work of it though!
crazyjr
crazyjr's Avatar
10.19.2006, 10:01 PM
On a rare occasion i have had to pry lightly with a screwdriver (very lightly)
