2wd stadium truck for drag? -
10.14.2006, 10:39 AM
Hi everybody.
In my area all that have wheels is drag raced, so I am planning on building a Mamba Max 2wd stadium truck to drag against the local nitro ones. I found that there a lot of aluminum parts for the Rustler drive train, so it looks promising. What are your recomendations for a good plattaform and hop up parts to cope with a 3s lipo 5700 Mamba Max power on drag racing?
Thanks:037:
Definately the Rusty....I wouldn't go with the 5700 setup though. I would choose a Neu motor with a Mamba Max ESC. How fast are they running at your track?
i am interested int the neu motors but the one you mention has an 5mm output shaft.
To my knowledge allmost all 1/10th electric offroad rc cars excluding tamiya use 48dp spur and pinions.
Do you know of anyone who sells 48dp pinions or is there neu motors that have a 3.2mm output like standard 1/10th motors.
Hi everybody.
In my area all that have wheels is drag raced, so I am planning on building a Mamba Max 2wd stadium truck to drag against the local nitro ones. I found that there a lot of aluminum parts for the Rustler drive train, so it looks promising. What are your recommendations for a good platform and hop up parts to cope with a 3s lipo 5700 Mamba Max power on drag racing?
Thanks:037:
what ever bushless setup you choose...
To answer your question of what will you need platform and hopup wise.
The Rustler definitely has the most potential to bullet proof. This is what you would need to make the drive train as strong as it possible can be.
I would do the dogbone conversion instead of the CVD's though. Also with an electric truck you should do really good compared to the nitros because brushless motors will make the truck accelerate so much faster than a nitro engine can. So I would say you could win it all if you can keep the tires on the ground and the car moving instead of doing a burnout.
on seths note i recomend that for drag racing you almost lock your diff. i am not aquanted with the rustler but if it has a ball diff setting it very tight will give the car a kind of posidrive that will make it accellerate very straght and true even when wheelspining.
secondly a drifting gyro helps keeping a car from spinning out when draging if you loose traction for example i could keep on the gas constant and the gyro would correct any rotation of the car and keep it true even when wheels were franticly spinning.
The Rustler actually has a planetary diff so...It's either all or nothing. I think some REALLY heavy grease might make somewhat of a difference, but I'm not sure....Anywho, the gyro idea is a good one! Never woulda thought of that...
I just had a look at Traxxas' website and it looks as though they offer a "Pro Ball Diff" as an option for the Rustler...I didn't know that...Seems as thought it might be an option...
Don't bother.... It's a piece of junk. I bought one, it broke in 2 packs and you can't buy parts for it. Just the whole thing again. Its not worth it IMO.
to make it...
or break it...
If your main goal is drag racing, why buy a 2WD stadium truck? A 4WD buggy will accelerate much better because you don't have to worry about keeping wheelies under control.
Thanks for the response. In fact I do own a couple of Grands cars. But locally we do have like a "2wd" stadium truck category mostly composed of nitro RC10s, I do want to bring an electric one to do the battle.:037:
