Eqaution...
AdmiralDog
Eqaution... - 10.14.2006, 11:49 PM
Well... Heres an equation for ya.
(old picture - now has kyosho trays)
___________________
:032:
squeeforever
squeeforever's Avatar
10.14.2006, 11:54 PM
An 18 celled Savage?
10.15.2006, 12:21 AM
Hmm. 9 cells + 9cells + Savage (with batteries already in it) = blank.
Does that mean it blew up? ;)
Since there is no result, shouldn't that be an "expression" rather than an "equation"?
Finnster
KillaHurtz
Finnster's Avatar
10.15.2006, 01:55 PM
10 Syntax Error
20 read "Does not compute"
30 goto Re-input values
40 end
Serum
Serum's Avatar
10.15.2006, 02:26 PM
Missing the
50 cls
finnster..
If you used a schulze controller i know what part is missing!!
captain harlock
RC-Monster Captain
captain harlock's Avatar
10.15.2006, 02:30 PM
Serum,
What exactly happenned to your schulze that made it burn?
Nice to meet you!
Serum
Serum's Avatar
10.15.2006, 02:51 PM
Loose contact according to schulze..
10.15.2006, 05:47 PM
Originally Posted by Finnster
10 Syntax Error
40 end
You need to convert that into a more current-day object-oriented programming language. That looks like Basic.
Finnster
KillaHurtz
Finnster's Avatar
10.15.2006, 07:26 PM
That's about the last time I did any programing :)
Format C:? y/n?
Welll..
AdmiralDog
Welll.. - 10.15.2006, 07:52 PM
Well.. i plugged in the 18cells and it wouldnt budge. The motor turned a little bit. but that was it.
Plugged in 14 cells.. and it worked fine..
Could something else be wrong except for maybe a bad sodlering job on the batteries?
10.15.2006, 09:27 PM
Format C:? y/n?
I always answer "y" to that prompt, but only if it's on someone else's PC. :)
Admiral: It 14 cells works and 18 not at all, that definitely sounds like something is wrong. Could be a bad solder joint, or a bad cell. If able, you could put a small load on each pack (like 50 ohm resistor or something) and then measure the voltage on each cell seperately.
monel_funkawitz
User replaceable parts were meant to be broken.
monel_funkawitz's Avatar
10.15.2006, 10:54 PM
I see a savage and two pics of a heavily abused pack.
crazyjr
crazyjr's Avatar
10.16.2006, 12:53 AM
Serum got you beat, he got a savage with a 2250 and 20 cells
