Originally posted by Dafni
If you can choose, go for a 5mm shaft. The hardened 1/8 shafts of the Lehner motors should also work well, I was told. But for Feigao's Nemesis, go 5mm.
Back in the days when I bought my TF, I got the helical ringgear and pinion from Tower. But I think Kyosho has an independent supplier in the states now. Maybe Mike can help you.
DAF
Kyosho is a little confused right now over here, so it is a little tricky to get the stuff. I am pretty sure I can work it out if necessary, though.
