11.30.2007, 03:18 PM
ESC:Quark 125b (will need the heat modification sooner or later after you start running it), or MGM 160/18.
Motor: 10lb truck, hmm,.... 9XL.
Lipo: Anything 5s? I would say maxamps, trakpower, trueRC- all the well known brands basically. Look for the voltage you want to run, a minimum of 4000mah, and 20-25c ideally. Obviously, the better the specs, the higher the price (true rc does 8000mah 10c packs that would be good; so long as the batteries can cope with the amp draw of the motor, you will be fine).
Whats your budget for motor and esc? there are much more efficient motors available than the feigaos, but with a lower kv rating like the 9xl it shouldnt be in danger of running too hot, especially with a fairly average weight truck- not a 13lb lump thankfully.
