Patrick
Patrick's Avatar
12.14.2007, 12:10 AM
I ground the shaft on mine. I never use loctite, and the pinion doesn't come loose. I don't grind the last 1mm or 2, so if the pinion does start to come loose it shouldn't be able to slide past the ridge at the end of the shaft.
