12.27.2007, 02:53 PM
hey BG, how about you use lutach's 200a controller when it comes out or maybe a CC HV110, and a neu 1527 1d (2160kv), and 12s 25c lipos (polyquest)?
esc: $270
motor: $433
batteries: $776
how does $1476 for a setup sound?
I agree that HV is the way to go. I am going to order a great planes 60amp hv esc and the programming card. I will try it on my tmaxx first, 10s lipo on a 20xl feigao should be ok, do not think it will overdraw the esc.
Brian, the use of smaller batteries and more cells would probably be cheaper. I have seen 15-20c 2100mah cells go for $10-$15 per cell. And I am sure that a 12s2p setup of those cells would be able to get you about 4hp. Run that thru a decent hv esc, castle, knotronic, etc.
I am actually reconsidering a hv setup for my yusa car. I will test it on 4s with the 2600kv motor, but may sub in a 1300kv and run it on 10s lipo?!?
I agree on parts availability, usually there are one or two parts that break fequently, so you would end up with quite a few rollers!
