04.02.2008, 12:36 AM
Whatever gauge is one the ESC. IIRC, the MM uses 13GA wire. If you are extending them, use 12GA if you can, but I heard that Castle uses solder that is difficult to work with. Just make sure you don't heat things up so much that the traces start lifting and/or burning out components.
