UPDATE........
so here is what i did this morning....
1. Removed 2.5 trans.....installed 3.3 trans (had to use the dremel some)
2. Added center diff, FOC, rear break, close gear ratio
3. Moved ESC mount to rear shock tower
4. 15T clutch bell, Robinson 40T Spur
5. RC Monster Heatsink,clamp
You guys ad asked if the rear arm would hit the motor and wires the way I had it installed. Well the wires were in fact hitting. I took your advise and mounted the motor with the wires on top. The motor will touch a-arms only if the suspension is fully compressed.
Things I still have to do.
1. Install novak fan to esc.
2. Shorten the motor wires
3. Install tekno wing mount
Not sure I will be able to put in on the road today due to the rain.
