teknorc
05.05.2008, 11:41 PM
Looks really nice!!
Is it possible to use the Tekno chassis, and servo mounts, battery tray and all that (except for the motor mount) and use the RC-Monster mount so I don't have to use the clutch? Also, will the battery tray fit the stock chassis? Will the mud guards fit the stock chassis?
Thanks in advance for any answers.
Mike will be able to confirm if the RCM mount will work once the kits are available. Just looking at it, it looks like there shouldn't be an issue. You may have to remove the rear brake assembly, but not 100% sure. The kit includes a complete clutch setup so you'll have it to try out either way.
The battery tray was meant to fit our chassis specifically. However, it could be used on other chassis' if you space it up 2mm off the chassis for the straps to clear. As it is now, the chassis is cutout underneath the battery tray to make room for the straps. Our chassis is actually lighter than the stock chassis by .5oz despite it having a bigger overall footprint. The truggy chassis is over 1oz lighter than stock :)
Tekno RC - Performance Parts
