07.07.2008, 11:14 AM
A123 just use the main power lines for + and -'ve and hence just need 1 line for 2s between the cells and 2 points for 3s.
Hyperion taps are different and have + and -'ve along with the intermediate points within the tap.
As John says you can just create your own +'ve and -'ve points off of the deans connector and build a hyperion tap connector. The LBA 10 manual includes the wiring diagram for the taps. see here http://aircraft-world.com/prod_datas...ba10/lba10.pdf
Standalone male taps can be purchased here http://www.allerc.com/product_info.php?products_id=3169 for $2.25 or this for http://www.allerc.com/product_info.p...oducts_id=1884 $1.89
The easiest way is to:
- buy this second tap http://www.allerc.com/product_info.p...oducts_id=1884
- Use this http://aircraft-world.com/prod_datas...ba10/lba10.pdf to reconfigure to a 2s pack i.e. 3 wires - 1 red and 2 black
- Red goes to +'ve on deans
- Lowest black (furthest from red) goes to -'ve (black) on deans
- Middle black joins to A123 tap
