speedracer1129
08.15.2008, 11:24 PM
Originally Posted by B15 View Post
The stock plastic diff outdrives and stock aluminum driveshaft cant handle much, but those are easy fixes.
The stock center drive shaft will work with no problem.
Neither, the magnet wont seperate, but itll run too hot for the magnet to hold its strength for long. Its doable for short runs.
Too hot in what sense?? When you set up a car for 100mph speeds, you are not going to have a car that will play for 10 minutes straight! We get about 10-15 passes of about 600 feet with the setup before it hits about 170-180 on the motor and 150-170 on the ESC, We then let it cool down for about 30 minutes before running them again. This setup also consists of no extra cooling added!!
