ffactory666
08.22.2008, 06:20 PM
Originally Posted by CRTIM View Post
Very nice build ...I'm in the process of converting a CRT-x1 truggy...my first conversion......I have the stock tire/wheel combo ..my tires seem a lot wider then yours ,what tire/wheel combo are you running ? i would like to go to the narrower tire like yours....i was afraid to notch my motor mount (same mount as yours ) as i didnt want to weaken it any ,does it seem ok with the notch ?...thank you for the help and any advice ....
No problem notching the mount , just do little at a time until it just clears , there is plenty of meat left on it .
As Arct1k speciified they are stock LPR tires and wheels , they look narrower because they are the largest wheel you can use under the rules so the tire is stretched out more and has less sidewall / tire looks narrower .
Tires are great they work similar to Crimefighters .
