bdebde
That's All Folks!
bdebde's Avatar
09.04.2008, 09:57 PM
Originally Posted by TRUGGYMAN View Post
I just received a MGM type E 28025 with 2fans, hydro version & switch.
Why did i choose MGM ?
The 1st MGM i bought in January had a software mistake in voltage
cutoff. They took it back and update it with new software + possibility
to personnaly update it at home, with nice compensations !!
Since march, the N°1 runs ideal: temp maximum 45°c !!!
Never had a broken fan after 42 packs ( 10 to 15 min ). I bought a 2nd one and they both go PERFECT.
A friend bought a MMM, already broken fan, software problems, weldings going bad and now no more life even with smaller motor in a buggy.
I prefer to go away from defaults.
I like the features of the new MGM version and i own a LOSI 8T that has just been converted for neutron
I made a mistake in the basic programming. Send a mail to MGM and
4 hours later, the answer was there: job done.
Tomorrow, i'll test it HARD
Can't wait to hear how it runs! I always recieve very prompt emails from MGM too. I had emailed back and forth about three times in less than 2 hours one time.
Originally Posted by captain harlock View Post
How did you find the braking? Does it fade?
What about acceleration? Is it smooth enough to compare it with MMM?
The new specs seem very tempting, and I need an effecient HV esc.
I only want to run 8s with my 1950/10 in the MBX5T. That would be totally cool...
On my 16024 with the old software, the braking seemed inconsistent and reverse was unusable. It also started out with a launch, no slow starting. After the software update, the brakes were very consistent, not quite as strong as MMM, but that can be turned up. Reverse works perfect, in fact better for bashing than the MMM, you can actually brake in reverse without launching forward. The start up works as good as the MMM (maybe better), and it is nearly as smooth. I won't hesitate to get another MGM if my MMM does not hold up. In fact I may get a new one just for some of the new features. Get one, you won't be sorry!
