10.01.2008, 02:56 PM
If you have set the voltage on the BEC you can just "remove" the orange wire on the bec lead - It is this what causes the issue (IIRC the signal wire looks like ground on startup and hence the rx thinks it needs to rebind) OR CC IIRC will swap the bec for a newer model which doesn't have this issue OR you can use a Y adapter on one of the other channels.
