drkdgglr
10.15.2008, 03:17 AM
Originally Posted by Unsullied_Spy View Post
I like longer motors because they generate more torque, the more torque you have the less work the motor has to do. The problem is that they also draw more amps so you have to balance the length, KV, your batteries voltage, the weight of the vehicle, etc. It drives me nuts trying to decide which motor I want.
This is exactly my feeling too. Although the speedcalculator and these forums are a great help, it seems impossible to chose 1 motor and getting it right from the start, especially if your setup is different than common setups.
If I understand correctly:
- larger can motors with the same kv rating produce more torque than smaller can motors.
- lower kv motors produce more torque than higher kv motors with the same can length?
So if a have a setup geared for 40mph and I need more torque (and don't want to sacrifice speed) I could:
- get a larger can motor with the same kv rating;
- or go for a higher voltage setup with a lower kv rating/ same can length...
