RBMike
RBMike's Avatar
11.06.2008, 11:48 AM
Originally Posted by JaySki View Post
At least half of this issue here is related to a few noticing a possible issue with their and everyone pulling theirs apart.
I'd be willing to be that the wire routing is shifting from just trying to pull the stuff part.
Wrong, the fan wires are undisturbed when you remove the bottom of the case. The edges of the CCA are very rough fiberglass which makes a great saw. When they break the boards off of the panel they should be at least clean up the edge. For those of you who do not know, boards like this come in large panels that are scored between each individual board & the broken apart at the score lines. This process leaves very rough edges on the boards. The rough edges are not a big issue unless you let them rub against something like fane wires.
