GO-RIDE.com
11.09.2008, 02:56 AM
Originally Posted by riceman View Post
This was long overdue. Since the original post I have since done a few updates. I'm now runnning a 50mm Medusa 3300KV motor. I also beefed up the suspension with Jato shocks up front and 1/8 scale Jammin front shocks in the rear.
Riceman,
I just did a test run at the backyard track (big for a backyard) with the Medusa 50mm x 3300 on 3S and my e-crt.5 was a wheely machine at anything more than 1/2 throttle. I even pulled a backflip on our 20' long by 6' up step up. My truck was a full 6' over the top of the landing and jumped at least 6 ft past the landing.
I'm running the Rhino (zippy) 3S 4000 25C batts. They seem to have huge punch. Your 3300 on 3S did not look nearly as wheely happy. What MM settings are you running? What about diff setup? The lipo I run is about 335gm, and I run it all the way forward on the RCM chassis and even have the MM mounted on the steering servo to further get weight forward. I even increased the anti-squat to 3 degrees to cut down on rearward weight transfer. Any other ideas?
Thanks,
Scott
E-8ight - Tekin RX8 2000kv/4S
