E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
12.27.2008, 09:23 PM
1/18 scale isn't of much use unless you have a near perfect area to run. Parking lots, basements, carpet tracks, or a scale track that is groomed to perfection. Build yourself a CRT.5! You won't be disappointed! It's 1/12 scale, slightly shorter wheel base than the rustler, comparable ground clearence so small obstacles aren't such obstacles! Very durable. I've put at least 30 full packs through mine and I broke 1 front a-arm and a turnbuckle. The original size tires are the same as a traxxas bandit but it can run 1/10 truck tires such as off a rustler if you gear accordingly. It has 12mm hex which is the same as traxxas rustler/bandit/stampede/slash. The slash tires are pretty good for bashing.
As far as getting an E-Maxx to be reliable......GOOD LUCK!
RC18T is a decent little truggy but keep in mind it is small and don't ask to much from it if you get one.
