GO-RIDE.com
01.01.2009, 12:37 PM
The crt.5 steering rack / servo saver is a bit of a weak link in that car too. If you run stock buggy wheels and don't get too crazy it's fine, but if you run truck wheels and a over powered motor you will want spares. It also helps a lot to run the drag link in the inner holes on the steering rack. You loose some steering, but rack is a lot stronger. To get the steering back you can buy the aluminum knuckles that have 2 sets of holes. The inner holes get the steering throw back. I've also drilled inner holes in the stock plastic knuckles and this worked well too. In the end I spent the $ and bought the aluminum version. Its been great.
E-8ight - Tekin RX8 2000kv/4S
