George16
Supermaxx
George16's Avatar
01.28.2009, 06:32 AM
Seeing the picture now, the monoblock will be perfect for that setup.
1. You can buy the straps from Gorillamaxx or RCmonster or you can cheap out by making it yourself. I made mine.
2. I second Shaun on this; use the 7075 GA unless you really want to run the VBS.
3. I had been using the racerx shocks(4shock setup). Black springs on rear and blue springs in the front. I'm running 50wt oil all around.
4. I'm also using the 8 spyders with 3K rear and 7K front.
I recommend UE EXT suspension for the ultimate basher setup.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
