yes its a beast
alangsam
yes its a beast - 02.01.2009, 09:06 PM
definitely a beast - wheely at ANY throttle point. you cant give it full throttle - spends all its time on the wing. i am sure its going 50+ across the soccer field.
points out how light the revo front end is - need to put some weight up there?
Well, you may need to rebuild the slipper since you smoked it. Best method is to set the slipper tight, and then back it off incrementally until it slips too much. Then tighten it a bit and you re good to go. 8xl on 6s must be a beast...
