change your pinion to 13t and the cogging will be reduced
alangsam
change your pinion to 13t and the cogging will be reduced - 02.04.2009, 01:03 PM
i believe if you change the pinion to 13t the cogging will be much less due to gear reduction and the thing will still fly.
That is not cogging! Have you tried it in your car? Motor/esc needs a minimum RPM to establish rotor position and function properly. cars/trucks/buggies all use gear reduction so that's not to much of an issue. I have aprox a 13:1 reduction on my REVO so every 13 turns of that motor only turns the wheel once. without a load on the motor you are going from nothing to about 20,000RPMs!
