Just picked up a motor for the flm savvy
Just picked up a motor for the flm savvy - 02.18.2009, 11:41 AM
Anyone who is familiar with the flm tranny forward savvy knows that motor choices are a bit limited due to the proximity of the motor to the batts. I was originally looking for a 1521 1y smooth can, then went to a medusa 80mm 1600kv. Both were to be run on 6s lipo and a MMM. I plan to get the flux single speed parts for the tranny, so that I can ditch the mech brakes and servo.
Well, I ended up finding a deal on a 1521 2y (780kv) for 80 bucks shipped! So I have decided to use that on 10s lipo with the lutach 10s esc I have. Looking at the speed calc I am guessing the flux tranny ratio is similar to the 2nd gear of the 2 speed. With 7" tall moab 40 series tires, 16-18/47 gearing should put me where I want to be. Not sure how the motor wil perform running around 30k rpm, but we shall see. All I lack to finish this is the flux tranny parts... Hopefully they wil be available soon!
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1.640953716690042
Other Ratio: 1
Spur Tooth Count: 47
Pinion Tooth Count: 16
Total Voltage: 37
Motor KV: 780
Tire Diameter (inches): 7
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.025
Spur/Pinion Ratio: 2.94 : 1
Total Ratio: 15.94407 : 1
Tire Circumference (inches): 21.99 inches (558.58 mm)
Total Motor Speed: 28860 RPM
Vehicle Speed: 37.69 mph (60.55 km/h)
