jahno30
03.03.2009, 03:14 PM
Originally Posted by SpEEdyBL View Post
The 2200 with the gearing you use now with the 2650, will yield about the same results as just gearing down the 2650. Basically, increasing the length of a motor (as is the case with the 2650 to the 2200), is almost the same as adjusting the optimal range of pinion gears.
If this is the case, then what do us new B's need to be doing to get a set up to run for 20-30 mins without blowing something up...
