padrino
hmmm...
03.04.2009, 10:37 PM
WHy do you need a 17mm nut. I just used the 17mm hex adapter and clamped it between two nuts and washers on the shaft. It works great and it is terribly easy to remove and install a wheel to do the balancing work. YOu have to think outside the box sometimes to achieve your goal. I like the look of the Hudy balancer. Maybe you can remove the bottom plate and extend the balancer somehow by threading a piece of allthread into the stantion, and mounting it directly onto your workbench. I am sure there is a way to make it work for MT wheels.
I am looking to do exactly what you say clamping it between two nuts, the issue was that all of my current 17mm nuts are a different thread size so none of them screw on. I am changing gears and making it work now but the point of this thread was to see if one would work out of the box, if I wanted to just make it work from the start I wouldn't have posted. It has been a good discussion and we know now that truggy != MT for any of these balancers.
