07.04.2009, 02:54 AM
Hey paralyzed, do you have a g3r that you can test this mount in?
it would not be bolt in. it would probably require grinding of the chassis rails(its wider than the rails, but depending on how it lines up you might not have to) and it would require mounting holes drilled in the chassis.
very doable, if you're a diy'er.
