09.29.2009, 01:19 PM
Originally Posted by J57ltr View Post
There is a HUGE difference between Load and overvoltage. We are talking about the load, it seems the ESC is more than capable of handling that. What we are talking about is damage to the ESC through braking.
Ok, I understand we are talking about braking. It was my understanding that the voltage spikes that are produced during braking need to be absorbed by the battery. A battery with a high IR will not be able to absorb the voltage spikes as well, and that can lead to damage to the TVS and eventually cause the MMM to fail. I do agree that CC need to spec specific brand batteries, as that will likely be the only true cure. But the customer needs to be informend, and I always see that as the responsibility of the customer. If you do research before you buy something no one calls out the mfg for that... This is a hobby, and it is generally understood that if you want to participate you need some sort of intelligence. So expecting everything to be written down might be a bit much.
I cannot believe the heat issues that would be had using nimhs with the stock gearing on a flux, but they still say it can be done... Not the best idea if you ask me...
