Deahttub
02.20.2010, 02:10 PM
Ok, moving the grub screw will not help.
The lst pinion needs to have the couple tight against the inner bearing race of the outside bearing. If not the pinion will "walk" into the diff case and cause mesh issues.
I have the original rcm steel couplers like you pictured, I will get a shot of them at work today and you will see what needs to be done. The center hole needs to be drilled to 8mm all the way thru. that way you can slide the couple down and have it touch the inner race and the pinion will stay centered between the bearings.
I drilled one all the way through and the grub screw still doesnt match...I don't know what I did wrong, but the hole isn't perfectly straight, so I guess i ruined one...the grub was still high, and lowering (the grub screw) it could help but it wont be a perfect fit i can tell you that....I emailed Mike and I'm still waiting for a response....
