02.20.2010, 02:58 AM
Put shims between the coupler and the bearing. I used the adapters that Mike makes to use the stock emaxx center slider driveshafts. They worked perfectly for me. Are you using dogbones? I used ofna hyper cups as well and they did fine too, with mip cvds. Maybe a link to the coupler you are using might be helpful?
