proVzone
proVzone's Avatar
02.23.2010, 12:04 PM
If you are looking to run 2 3s packs in a series for 6s total, I'd look to the Feigao 11XL as it will be more suited to 6s with its Kv of 1577.
I'm not sure what ESC you have here, but are you sure it has brakes and/or reverse? Most chinese ESC's are forward only and meant for air use. If this is the case, you'll most likely need to maintain the mechanical brakes and obtain a PiStix to properly run the ESC.
As far as the conversion, you say you want cheap, but quality is cheap then as well. Mounts bend and shit breaks.
Why not support the man running this site. Mike offers the best quality mounts around and has trays and conversion kits for the RC8B.
FULL CHASSIS KIT
Or
Mount only
Great info thanks , as for the stuff you recommended its way over my budget for the start of this build ...I may upgrade later.
The ESC has full car options such as drag brake and reverse etc.
Which wheels/tires do I go for ?
  Send a message via Yahoo to proVzone Send a message via MSN to proVzone
