crusey_aus
02.25.2010, 06:58 AM
Given that your Neu 1112/2d is rated at 35 amps cont / 70 amp burst, on the conservative side pretty sure they are capable of much more
You will need an esc that will support that sort of current draw
The Micro pro is just on the borderline of supporting such current, it's rated at around 35a cont (not advertised I believe)
I wasnt suggesting that you run the stock esc just making you aware that the stock esc is rated at 52a cont / 320a burst
Pretty sure the Neu motor would not work with the stock esc as the rev limiter would limit you to 25,000 rpms (2 pole vs 4 pole motors)
I would grab yaself another Mamba Max ($100 or so) or even the Pro ($125 or so)
I notice in your signature you are running Zippy's
You may want to upgrade them to get the most out of your combo
I've done a heap of lipo testing and at large current draws there are better options
I run a Mamba Max / 4600 combo in mine
How did you mount the Neu ? Did you modify the shock tower ?
What pinion / spur setup do you use on 4s ?
Cheers
