Go Back   RC-Monster Forums > Support Forums > CORR Trucks - Slash, SCRT10, etc.
ausjethro
Thumbs up 04.05.2010, 01:18 AM
Originally Posted by JoFreak View Post
Thank's ausjethro,
as far as I have gathered there is a 13T pinion included in the kit, and a 3mm to 5mm shaft adaptor as well. And if I needed an adapter, I would most likely get one from Mike, as well as the pinions. Provided those stupid shipping costs in the shop-system go down. 30$ shipping for a hand full of pinions which fit into an envelope that needs ~1.5$? Really? But that's a different story...
As servo I will use a Thundertiger DS1015: 14.5kg/cm and 0.108sec/60°. Should be fine, have read form a lot of people who use it in their MTs.
What do you mean with "doesn't feel right"? To much power? Not enough power? Doesn't pull hard enough of from the line? I will try the VXL though. If it won't work out for me, I still have a Kontronik Twist55 lying arround. Would need to gear down then I guess
If this all fails, I'm thinking maybe Plettenberg Extreme or Shadow, or maybe I'll get a Lehner, 1920 or alike. But I won't get a Novak because they are about 150$, with shipping and taxes they're probably more expensive then the Plettis and about the same as the Lehner.
I'll see...
Hope the kit arrives on Tuesday
When I said the VXL"didn't feel right",I guess that it is basically a 1/10th scale system in what is really a vehicle close to 1/8th scale.Call me conservative, but I like the option(and insurance) of a 5mm shaft running a metal pinion and spur gear ,especially in 32 pitch.Don't get me wrong,I run a vxl 3500kv combo in one of my AE SC10's and it is sweet,but I feel that the Novak HV PRO is better suited although they are both similar in performance.
At the end of the day,I am sure you will be happy with your Hyper 10SC-it has to be close to being the best short course truck on the market today!
Regards,
Jethro.
