Go Back   RC-Monster Forums > Support Forums > CORR Trucks - Slash, SCRT10, etc.
JoFreak
JoFreak's Avatar
04.04.2010, 06:04 PM
Thank's ausjethro,
as far as I have gathered there is a 13T pinion included in the kit, and a 3mm to 5mm shaft adaptor as well. And if I needed an adapter, I would most likely get one from Mike, as well as the pinions. Provided those stupid shipping costs in the shop-system go down. 30$ shipping for a hand full of pinions which fit into an envelope that needs ~1.5$? Really? But that's a different story...
As servo I will use a Thundertiger DS1015: 14.5kg/cm and 0.108sec/60°. Should be fine, have read form a lot of people who use it in their MTs.
What do you mean with "doesn't feel right"? To much power? Not enough power? Doesn't pull hard enough of from the line? I will try the VXL though. If it won't work out for me, I still have a Kontronik Twist55 lying arround. Would need to gear down then I guess
If this all fails, I'm thinking maybe Plettenberg Extreme or Shadow, or maybe I'll get a Lehner, 1920 or alike. But I won't get a Novak because they are about 150$, with shipping and taxes they're probably more expensive then the Plettis and about the same as the Lehner.
I'll see...
Hope the kit arrives on Tuesday
