slimthelineman
slimthelineman's Avatar
04.25.2010, 12:06 PM
wow.... i would hope most in this hobby were proficient at soldering. the are you want to solder is very small, just use a good clean tip and touch both pads at once (bridging it) and just dont run a switch. just do it fast with a hot iron. dont want to put alot of heat into the pcb. take your time and it will be fine. one less set of wires to worry about!
