Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
04.30.2010, 10:18 AM
Originally Posted by jpoprock View Post
So, to do this on the DX3S, I should get a BEC. I've never actually owned or used one. Do you program it via a PC or card?? What Voltage do I set it at since my radio uses 4AA's? 4.8? yep, I'm a ri-tard. Also, I can use whatever MAH I want... as long as it fits inside right? And 2s? 3s?
Hey Goofball,
I'm using the little blue BEC here; http://www.castlecreations.com/products/ccbec.html
I think mines set at 4.8-5.0, programable via the PC just like the ESC's.
And I'm currently using 3s 20C 800mah packs and they last about 6hrs non stop. I carry a spare lipo in the case just in case, they were 6.00- 7.00 a peice at HC.
I would look for somthing with higher MAH, I will next time I need new packs.
You can easily make more in the battery compartment via a Dremel but still be able to reinstall the 4cell AA tray if needed.
To honest w/you, this mod is not for everyone. If you only use your TX say a few hours a week I'd stick with the AA Duracells and save yourself the work and hassle.
