HotnCold
HotnCold's Avatar
02.16.2006, 09:57 PM
yep - and if you get all the screws tight - and you can spin the flywheel easily by hand - then the compression is not good - also - it will loose all low end grunt - if its got no compression - you either need a new piston and sleeve - or a new motor - sorry to be the bearer of bad news..
Hows that "Hope and Change" working out for Ya???
