danielc79
08.15.2010, 10:08 AM
i had a set of aluminum rims, now i have a pair of aluminum rims lol
i think if you never leave the ground they should be good, but even small jumps landed wrong can make them useless.
for the record though, i've never had a problem even with 14mm hexes as long as everything is tight like you said, but of course if a pin breaks your sol.
i use the stocker tires off a cen genesis with some 23mm hubs and they work good but the stock pins for my flux are alot smaller than the pin gap on the hub and they can move around quite a bit, so i've had several snap b/c they were too far one way or another. You think they have longer pins that could help with that that will still fit the stock axle size?
