Charging at more than 1c with Duratrax Ice?
Emaxx_Quebec
Emaxx_Quebec's Avatar
Charging at more than 1c with Duratrax Ice? - 11.02.2010, 08:27 PM
Is it safe to bypass the 1c limitation by lying on mah capacity?
Ex: I have 3s 5000 so I can't charge at more than 5 amp.
If I set it up as 7500 mah, I can charge at 7.5 amp.
Will it peak correctly or not ( And I use a LBA10)
Is the mah setting is there as a title or it does somethig at the charge (Peak).
Thanks
Fred
