simplechamp
simplechamp's Avatar
12.03.2010, 03:17 PM
Kyosho spool should fit fine. Hot Bodies, 777/IGT/ST-R Kyosho, Jammin, and most Ofna diffs are pretty close in size. You'll always need a few shims anyway.
I am going to be using a Slipperential so if I'm going to lock it I need a temporary solution that can be removed at some point if I turn the car back into a buggy. Does the Ofna Diff Lock lube work any good?
