thzero
01.12.2011, 06:05 PM
If its closer to 22" you'll probably be just fine. I know I had at the LHS a 5T body on my TCS Crawlers 5T conversion and while it worked well, it was definetly huge. Unfortunately didn't get any pics, doh.
Due to the construction differences, the 5B body, is actually a tad short by about an inch. So you could probably run a 22" wheelbase to get it to better fit. I'm having to run about a 22" wheelbase, because of available dogbones, myself as I convert to a center diff. But it helps with using the 5B body and rollcage.
The baja body I have is the proline body 5t body that fits the 5b. Not sure if the wheelbase is different, but I will have a finalized dimension when I put the rc alloys front driveshaft in and measure the result. Will do that later and see how the body looks. But rough math puts me somewhere around 22 to 21.5" for wheelbase.
