05.17.2011, 04:07 PM
Originally Posted by radioman193 View Post
you can get them on Ebay for like $20 or so.(ek2-0704B)
This is the one that i got BUT you will NEED a Third Ch for this one.
I don't understand this. I looked at the manual and it appears that the connector with the yellow wire JUST has that one wire in it, and it's a signal wire, not power or ground. What happens if you don't look it up? Hooking it to an unused CH3 receiver input seems redundant.
From your directions, it appears that the red/black/white cable carries the corrected servo signal and power and ground.
I could understand the need for the yellow wire if that was the one that needed to be inserted into CH1 (steering).
