MM 5S and the LVC
riceman
RC-Monster Gold
riceman's Avatar
MM 5S and the LVC - 01.26.2007, 06:27 PM
Well I'm pleased to say that my setup on my LST2 conversion is working great. Finally got my ESC mounting, wiring and battery tray issues solved. I've been running 5S 6000mah Maxamp pack with the LVC on the MM custom set at 15.2V without any issues. Well I often switch between the 5S and a 4S pack and when I went to reset the LVC the Castlelink software prompted me to upgrade to the latest revision. Without thinking about it I did the update. Now here is the problem. The ESC now cuts out almost immediately with the 5S pack. Almost like blipping the throttle then no response at all. Without resetting the LVC it will run fine with the 4S pack. Now if I select Auto-Lipo for the LVC the 5S pack will run. Anyone else run into this
