MGM controller...
orangecrush
MGM controller... - 02.13.2008, 11:44 PM
Okay, I've bothered Mike enough but can't seem to get this done. If you don't remember, I was having problems getting into programming mode in my 16018 MGM controller.
Turns out that my controller was defective from the factory. Mike checked it out, agreed and had it replaced.
Well, I received it today back with the motor and this time, I bought the USB cables to do the programming.
I installed the program, changed the parameters and it worked like a charm.
My problem now is once I write the saved parameters to the controller, Mike says I need to set it in "autotune" mode.
I had not tried this with the transmitter, only the software.
I clicked on autotune and the controller beeps 3 times. The instructions says to unplug the cc02 cable without turning off the controller and then drive it and go into full throttle so it can "autotune".
Now my question. Is this correct, can I use the software to enter the autotune programming mode?
If so, what is the correct way.... apparently I am doing something wrong.
Second question. At this moment, I only have half throttle. Pulling the throttle just past halfway point gets me nothing.
I'm not sure if this is from not going into autotune mode or a setting I have set incorrectly.
Any help would be appreciated.
Thanks all....
Mark
