ANGRY-ALIEN
ANGRY-ALIEN's Avatar
08.05.2008, 11:50 AM
Originally Posted by bensf View Post
Do you know what your timing is set at? I've heard that this can happen if the timing is too high. I'm not entirely sure about it, but it wouldn't hurt to check.
I am not so sure I know how to do that... Can you explain how?
It sounds like you may have cooked it. It's possible though that something has just come unsoldered though. It may be possible to repair it.
I have not found any burnt element or loose items yet... I however saw a little dent in the back of one capacitor, not sure if this will be causing the trouble.. I think this happened during the crash too, not sure though... You can see the images below..
Originally Posted by 83gt View Post
I had a bk that behaved the same, and I found a resistor on the back that was hanging half off the PCB. I replaced that resistor and it ran good until I shorted the motor wires and smoked it. Not sure if that could be an issue with you. I'd go ahead and remove the shrink wrap and give it a good looking over.
J>
The boards look fine... every tight...
Alien
ID:	5180   Click image for larger version
ID:	5181   Click image for larger version
