lutach
lutach's Avatar
09.07.2008, 09:20 PM
I guess you bought it used. I loved used RCs myself. The first thing I always do is disassemble the RC, check everything and fix all the needs to be fixed. You should definitely open your diffs and get fresh hardened internal gears for all of them. I use a locked center so I can't comment on the weight of oil you should use. I use 10K in the front diff and 5K in the rear. I might switch the rear to 7K as it's working great in my MBX5T. Other members will post their set up as well and some of them are racers, so what works for them will most definitely work for you.
