riverat1540
riverat1540's Avatar
04.21.2007, 08:55 PM
Originally Posted by AAngel
I'm going to assume that you are using a Mamba Max esc. The 5700 would be somewhat of an upgrade. It's simply by virtue of the fact that the 5700 turns more rpms per volt than the feigao motor and the 5700 has the torque to be geared. On 3S lipo, assuming 3.5v per cell under load, the feigao will turn about 51,500 rpms. The mamba motor will turn about 60,000 rpms on the same voltage. Are you running this in a 1/10th scale? The fastest readily available system is probably a Mamba 4600 on 4S.
what about the fiegeo 380c 7t its just a bit more kv than the 5700 but would it work. this seems to me the fastest option on 3s i can find by not pushing the limits too far. im thinking i would be ok
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
