Okay, if i understand this right, you are using stock diffs in the 1/8th housings?
This wouldn't work, because they use a different size of bearings, and the bearings for the 1/8th conversion are flanged to keep the diff in place. (centered)
I had this issue when I installed mine too. I got a set from the very first batch and when I installed them the output pins were slighty to long. I had to split the bulks to get them in. I told Mike about this and he said that he had made the adjustment for all future production. Did you get some of the very first release? Any newer ones out there should not have this problem.
I'm planning on changing out the outdrive pins on mine when the first time I tear them down to replace fluids and stuff.
Even if you have to split the bulks its not that hard to do. Just a few screws and the bulks split and they drop right in.
to make it...
or break it...
Brushless Jammin Truggy on NEU 1515 2.5 D on Monster mamba max with maxamps 5000mah 6s Lipo
Gorillamaxx Revo CF version on Mamba maxx ESC with NEU 1515 1Y on Maxamps 4s 8000mah Lipo
