BlackedOutREVO
05.13.2007, 05:47 PM
Originally Posted by BrianG
Nope, the diffs should be just fine. Of course, over time, you are gonna want to change the fluid as it'll probably get dirty (as any diffs do).
No one knows about the spurs yet. I wouldn't go buying Mod1 just yet, because I think the spur for the .5 will be 32p, but not sure yet. Hardened pinions would work as long as the gear mesh is VERY solid, but finding a small hardened pinion (~13T) that is Mod1, yet with a 1/8" bore can be difficult.
A normal servo should fit if you cut the mounting tabs off and stick it down, but it probably would weigh more. I would measure just in case.
i dont care on wieght, one less thing i have to buy, my spektrum came with those 2 servos, and i could use those, id rather do that then buy more lil ones..could u mesure for me? i dont have mine yet
what pinions are u using?
if it works for u, works for me LOL i will use mikes mount, with the cf batt tray, and prob a top deck to go with that, so i tihnk flez will be fine, but id like to do mikes stuff
and yeah i know cleaning, just dont want stripping on me lol
thx for the help!
and i will cheack out that servo
