05.31.2007, 01:21 PM
I can't tell, but if your radio is a Futaba (or Futaba-based radio) you will probably have to reverse the throttle channel.
So you have the throttle trim set to 0 (centered) and the EPA set to 100% both ways.
nastety92
05.31.2007, 01:34 PM
I'm using the stock AE radio and receiver that came with the truck when it was a nitro RTR.
Nick
05.31.2007, 04:59 PM
Nick
OK, did you set the trim to centered and EPA to 100% (if available)? When calibrating the ESC, it needs to see a certain range of throttle throw. So, if you have the trim off center and/or EPA set funny, it might not want to calibrate.
nastety92
05.31.2007, 05:07 PM
Thank you very much Brian, I will try this when I get home.
Nick
nastety92
05.31.2007, 06:06 PM
This is the radio that I have, I have tried it a bunch of different ways and I'm still getting the same result. I'm sure its just me doing something wrong.
http://www.teamassociated.com/shusti...adio/index.htm
Anything else I can check or try?
Nick
